RE: Engine Problems
After removing the exhaust from mach broken Mach, I seen allot of small silver shavings. Is it safe to use this on my new engine? Anything special I should do to clean out the exhaust? Also, should I keep the O-Ring? The end of it ripped a little bit when I removed the exhaust, should I replace it? Also, do I keep the carb or send it back with the mach as well?
