RCU Forums - View Single Post - Brison 3.2 starting problems Help ASAP
Old 07-11-2005 | 02:02 PM
abacro
Default RE: Brison 3.2 starting problems Help ASAP
your problem i dont think is with the settings,but with the EXHAUST! it sounds like you have wayyyyyyyy to much back pressure causing the over heating.I had a 4.2 doing the same thing,turned out the muffler was restricting the exhaust flow causing the motor to get hot,and not draw fuel correctly. By changing my pitts style muffler to a bennet straight stack,is solved my problem.
