RCU Forums - View Single Post - monokote
Thread: monokote
Old 07-15-2005 | 08:01 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: monokote
You CAN use only solvent on MonoKote. There is a solvent called "No Heat" (Available at your LHS) that works very well - But while it works on MonoKote, it does NOT work on Ultracote (One of the advantages of MK)
You can also use Acetone, but you have to be a bit more careful with it.
