Boy that thing is heavy without anything on it! I still like the BB and it's 80" span. I didn't actully put all of that in the back to balance it with the G26. I used the pull-pull in the stock position for the ele and mounted the rudder servo in the rear on top of the fuse along with the battery. Also you need to make sure when you open the wing for the servos that you cut it in the right place. RVator cut mine and "uh-ohh"[X(]. Can't imagine those other planes flying better than the BB.
