RCU Forums - View Single Post - New Pull Pull setup!
Old 07-16-2005 | 07:44 AM
AcroJo's Avatar
AcroJo
Default RE: New Pull Pull setup!
Lee, on the servo arm I would use nothing but 4/40 ball links. Thats what they are set up for. The hole is actually sized for the bolt that goes through the link. Also check out the pull/pull adjustment rig for the wire. You could get away with clevises on the tail end. Good luck, Joe
