RCU Forums - View Single Post - Hitech 945 Centering problem
Old 07-17-2005 | 08:50 AM
lgodin
Default RE: Hitech 945 Centering problem
How old are the servos? Also, will the control suface more freely with no servo attached? I had a friend that had a similar problem, turned out that the robart hinges were not installed properly. If you surface is hard to move the servo will not be able to center it. Make sure the surface falls on its own when no servo is attached.
