RCU Forums - View Single Post - Wondering about a trainer
Old 10-16-2002 | 12:16 PM
Fastsky's Avatar
Fastsky
Default Starting over
I hope that you aren't planning on trying it alone right off are you? In that case I would say almost any plane will get you in trouble until tou get used to things again. You said that your friends own the field. Would one of them be willing to hook up their transmitter as a buddy box for a couple of flights for you? IF so, the H9 mechanically set to lower rates will probably work fine as the stick can land fairly slow. I say mechanically because dual rates don't work on the buddy box system. The buddy box will go to high rate right away. The other 2 planes that you have won't work as well. Best of luck, Fast!
