RE: e-flight - blade, blades
the flat bottom blades make more lift with less headspeed. Id learn with these first cause when you hit them on something the damage will be lower because of the lower headspeed. Ive flown both, I reccomend the flats also you have to run a lipo batt on the symetrical blades to have enough power to even hover, Later
