RCU Forums - View Single Post - Initiating Spin Entry
Old 07-19-2005 | 08:35 AM
Ryans Rebel
My Feedback: (12)
Default RE: Initiating Spin Entry
ORIGINAL: Rcpilet
I have a hard time getting my World Models Patty to break. It will also fly almost all the way across the box before finally dropping the nose.
I'm slowly applying elevator--more and more--slowly. My plane just looses altitude--but the nose never rises or falls. The plane just mushes down and looses altitude.
By the time it finally does stall and drop the nose--I have to SLAM in my left rudder and try to get my spins in before the plane meets terra firma. It drops FAST during the spins. Then level out about 50' above the dirt and add power. For me--big pucker everytime.[X(]
I do as suggested earlier--cut my throttle sooner. I'm also trying to exit my last maneuver at a higher altitude to compensate.
Add the elevator faster. From Neutral to full deflection should take no more than 5 seconds or so. This is a trick that I use. The nose will pitch up a bit but what you are doing is stopping the forward airspeed causing the model to have to stall. Feeding it in slowly is asking to see how slow the model will fly. The elevator needs to be feed in faster.
Ryan
