ORIGINAL: wgeffon
I firmly believe that properly set up, 3D capable designed plane, does not need to have an AFT CG to 3D well.
None of the planes I fly 3D with have a rear CG.
If a plane needs an AFT CG to do 3D something is wrong. Or, the AFT CG is compensating for design or set up issues.
You should 3D my H9 27% Edge with a forward CG. Ughhhh[:'(] For it to 3D it needs a really tailheavy CG, which is a pain because I have to add weight in the nose for IMAC because it's too much work to move everything around.
