RE: Canister's Tunnel exit shape
You definately do not want the exit hole area to increase, as that will lower the fluid velocity & raise the pressure. There will be some fluidic expansion due to heat rejection from the muffler, so either a constant area, or slightly convergent outlet will be OK.
Don't do the exit louvers -- this will act as a diffuse matrix & create a significant exit obstruction.
