RE: Jett 76L Any one tried one ?
Bob27s,
A couple of days ago, I sent several 76L questions to Jett but have not received the answers. I bumped into this post when I did a better job searching for 76L info in these forums.
One of the questions was related to running a 12" prop with the 76L. In particular, I was guessing that 12x7 or 12x8 might keep the 76L down to around 11K. Did you ever do the 12x8 or 12x10 prop tests that you mentioned? If you did some 12" prop tests, I'd like to hear what you think about running a 76L with 12" props.
Background info:
I'm trying to setup a 40-50 sport/pattern plane to fly at a field that has fairly low noise limits.
Thanks.
kec
