RCU Forums - View Single Post - After run q's
Old 07-21-2005 | 11:19 AM
EB4man
Default RE: After run q's
i was told NOT to use WD40 and putting the oil in through the fuel inlet doesn't work to great. The HSN is only open when full throttle. Easier to just take the air cleaner off and anyways your fuel tubing should be zip-tied to the nipple also. So I opt for removing the air cleaner. you know for a fact plenty of oil is getting in there!!
