RCU Forums - View Single Post - Canister's Tunnel exit shape
Old 07-22-2005 | 06:17 PM
rmh's Avatar
rmh
Default RE: Canister's Tunnel exit shape
Stop with the theory!
The idea of the large outlet is to make the job simple
More air can flow out of a larger hole
unless air flow is happening there - (you already know this )--no air flows in at front.
You DO want low pressure at outlet -
Make a lip in front of outlet - disturb the air at the lip and low pressure happens just above -in the hole
Cowl flaps on full scale , function in exactly this manner .
