RCU Forums - View Single Post - Genesis LE
Thread: Genesis LE
Old 07-23-2005 | 09:46 AM
  #60
ThermalRD's Avatar
ThermalRD
Default RE: Genesis LE
Aluminum crusher, i had the top shocks off while i changed the oil in them. It felt ALOT different without them, in a good way. I'll race with only 8 shocks on this truck. How fast is it going? I could only speculate, but its very fast. The next time i see a radar speed trap set up in my area, i'll do some speed passes on it. Right now, i'd have to say low 40's. Not sure what gear its hitting. Its speed is very impressive. Im also using 30% Odonnell fuel, and i did break-in with heat cycles. Which is NOT the method they say to use in the manual. Oh, and about the steering, i dont think anybody would believe me if i mentioned that. It steers incredibly well. I expected this truck to require a football field to steer. Thats just simply NOT the case. Im more impressed with this trucks performance than i am my TNX Pro. Steering, and speed... Keep in mind though, i do have this truck setup with all 3 diffs tuned. I gained more steering with each diff i tuned. I also have my toe in/out setup properly for steering. Other than that, all servos are stock. Atleast for a little while anyway.
ORIGINAL: aluminum crusher
That's finally good to hear something good about the Genesis LE. Hey Thermal RD have you tried it without the top shocks, and how fast do you think your going without hitting 3rd gear, how's the steering, and what brand of fuel you are using and at what percent??? Thanks Thermal RD for your reply's ( it sounds like the Genesis LE has been working out at the factory and it's ready for a rematch[sm=punching.gif])
