help, prop on modeltech p-47 arf
3 blade props are a bit less efficient than 2 blades. usually for a 3 blade the 3 blade wil be 1 inch diameter less than a 2 blade, for an engine.
i would recommend apc props if you can get one that is the right size for your engine.
