help, prop on modeltech p-47 arf >
Old 10-17-2002 | 02:18 AM
Default help, prop on modeltech p-47 arf
I was hoping for some prop suggestions. I am going to put a saito .92 in this plane and thought a 3 blade prop would be nice but don't really know anything about them. What would be the PROS and CONS of a 3 blade setup?
Old 10-17-2002 | 09:35 AM
3 blade props are a bit less efficient than 2 blades. usually for a 3 blade the 3 blade wil be 1 inch diameter less than a 2 blade, for an engine.
i would recommend apc props if you can get one that is the right size for your engine.
