RE: drift fast?
its all in the tires.... they pick up speed becuase of the tires they use more so then the motors.... if ur using PVC dont expect alot of speed.... if u can find ABS pipe its softer and still drifts and u can pick up some speed.... the simple trick is painters tape... or masking tape... put a good 8-10 layers on each tire... good as gold till it wears off lol.... try it out it does work
