RCU Forums - View Single Post - Help with Blade CP Issue
Old 07-25-2005 | 02:36 PM
liftdump
Default RE: Help with Blade CP Issue
becareful not to set your main blade pitch to high. hovering just over half stick is good(stock config). If you increase your blade pitch too much via the link arms your motor will slow due to the high load which will in turn slow your main rotor significantly during turns in flight when you add collective causing your helicopter to lose altitude/crash. Speaking from experience. My pitch accidently got to high due to setting the blade tracking time and time again.
