RCU Forums - View Single Post - spinner question
Old 07-25-2005 | 09:55 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: spinner question
Your pictures are a bit fuzzy, but I think I can tell what is going on. I assume that there is another piece that goes inside the spinner that the phillips screw goes into. That will be the adapter. That should thread onto the shaft of the motor (after you install the prop, thrust washer, and prop nut), and then you thread the screw into to adapter to attach it to the motor. See attached diagram
Hope this helps
Ken
