 spinner question >
spinner question
spinner question
Old 07-25-2005 | 09:36 PM
Mr. Canadian's Avatar
Default spinner question
this spinner came with the kit and i don't know how it works and the instructions doesn't say how i've added some pics of the spinner it has some spinning thing in the middle with a phillips screw
ID:	301501   Click image for larger version
ID:	301502   Click image for larger version
Old 07-25-2005 | 09:55 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: spinner question
Your pictures are a bit fuzzy, but I think I can tell what is going on. I assume that there is another piece that goes inside the spinner that the phillips screw goes into. That will be the adapter. That should thread onto the shaft of the motor (after you install the prop, thrust washer, and prop nut), and then you thread the screw into to adapter to attach it to the motor. See attached diagram
Hope this helps
Ken
Old 07-25-2005 | 11:37 PM
thanks RCKen that helped me fix the problem
