RE: Optical Kill Switch - FM vs. PCM Versions?
Thanks Tony,
I wasn't sure after I seen their warning about the JR receivers. In the past I ran their single receiver unit on JR equipment with no problems. I have plans on setting up a bird that will require two receivers and just wanted to make sure that there wouldn't be a problem with their dual receiver kill switch.
I wonder also, since their unit plugs into both receivers, does it electrically connect both receivers together or is there some type of isolation? One point of running dual receivers is the ability to keep both units electrically isolated to prevent a shorted battery from bringing down both units.
Take Care
Duane
