RCU Forums - View Single Post - Cheap-O Cox engine combat?
Old 10-25-2002 | 03:50 PM
CrazyHerb-RCU-delete
Default TLAR and Airfoils
The wing is only 3/4 inch thick (18mm) so there's not much to work with even if you had a hot-wire. The rest is just flat foam board the whole way.
Here's a quick drawing to give you the idea.
Not a lot of science or math to it....it just works.
