os max 40fp
We normally suggest opening the high-speed needle valve about 2-1/2 turns out from closed. This gives you a very rich mixture to start with.
The air-bleed screw should be set so that it blocks 1/2 of the air-bleed hole. We do this visually, by looking into the air-bleed hole.
The idle is leaned by backing out the air-bleed screw, and richened by turning it in.
