Originally posted by Big_Bad_John
I don't think I have an air leak.
No bubbles in the fuel line. I resealed
everything. No change. Thanks, any more
ideas, or how to check where the leak may be?
There's nothing to think about here. Engines won't run without air, period
If your carb barrel is closing 100% of the way, and it still runs, you have an air leak.
I had a Magnum the same way. I had to re-seal carb, backplate, and needle valve to fix it.
You might give the RTV idea a try. If this is a drawbar type carb holder, you may never
get it to seal with O-rings alone. (Carb or intake may be slightly damaged)
Also, slip a small length of fuel tubing over where the needle valve screws in, so
it's half on the needle, and half on the housing. That will eliminate this common air leak.
