RCU Forums - View Single Post - DA-50R Starting Problems
Old 07-29-2005 | 08:10 PM
Josey Wales's Avatar
Josey Wales
My Feedback: (61)
Default RE: DA-50R Starting Problems
I think the problem is that you NEVER choke it with the ignition off..you will flood the engine/plug..once the plug is wet you can flip till the cows come home..I think this is your problem..the only other problem I had was when the low end was to lean..
I put the choke on and the ign on and after 10-12 flips it starts then dies..then 3 more flips and it starts
