RCU Forums - View Single Post - Tiger 2 CG
Thread: Tiger 2 CG
Old 07-29-2005 | 08:48 PM
shakes268's Avatar
shakes268
Default Tiger 2 CG
Well, I bought a second Tiger 2 after the last "incident" I had with mine. Considering the wood was soaked I thought it might be better just to buy a new one and I could use most of the same hardware, etc from the first plane.
I've had it together for a couple of days now and finally maidened it tonight. Same servos (except for one), same engine, same receiver, same battery pack and same wing.
Everything else was new.
It felt squirrely!! The CG is within the recommended range - even took my CG machine out to the field to double check it. It's just under the 4 inch mark whereas the recommended CG is 3 1/2" to 4 7/16" (I think that is correct on the latter...any way, I am within the range).
It took 15 clicks of UP elevator for level flight so its not tail heavy. I flew it for about 8 minutes getting it trimmed but it does not fly not even within the ball park of my last one. I did a much better job assembling this one than the last one as well.
Any ideas?
