RCU Forums - View Single Post - HPI Nitro Rush Promblems
Old 07-31-2005 | 05:24 AM
matt121073
Default RE: HPI Nitro Rush Promblems
hi if you set your neddles back to factory settings and start leaning them from there you should get it heres how
first your low speed neddle should be flush with its housing this is its factory setting
the high speed neddle should be turned all the way in then 3 turns out
then start leaning the high speed neddle first until its running fast with some blue smoke then and only then lean your low speed
hope this helps
