RCU Forums - View Single Post - Official Nitro Evader ST Thread v2.0
Old 07-31-2005 | 06:36 PM
  #54
dicko's Avatar
dicko
Default RE: Official Nitro Evader ST Thread v2.0
put the shoes together, join the spring & roll it on. sometimes it is easier to leave the shoes on the fly wheel. if the old spring has a visible wear mark from rubbing on the CB, your shoes are worn as well. you will either need to replace them or cut the groove that the spring sits in deeper. you may also need to clip a bit off the spring to shorten it if this is the case. the white shoes tend to wear out pretty quick.
