Setting up the throttle link on LT-40, please help.
Hey All
I am building a SIG Kadet LT-40. I want to mount a SC52FS engine. It is a four stroke with a rear mounted carb. The question I have. How do you set up the throttle linkage? The throttle is in te middle of the engine with little space between the carb and the firewall. On the other side of the firewall the fuel tank also leans against the firewall. With the engine mounted, the fuel tank is "in the way" between the throttle and the servo tray. Would it be oke to mount the servo upside down close to the top op the fuselage and run the throttle link over the top of the tank?
Has anyone have any tips on this?
Marcel
