RCU Forums - View Single Post - Set ups of buggies - need help!
Old 08-04-2005 | 03:52 PM
crazychris7's Avatar
crazychris7
Default RE: Set ups of buggies - need help!
A good neutral setup is... 2 degress camber front and rear, 1 degree toe out in front, 35 front, 30 rear in shocks, 5k<7k<3k in diffs. Front arms should be level with the ground after compressing the suspension a few times and the rear shafts should be level. If you are pushing alot in the corners, i usually run w/o the front swaybar because it gives you a lil more steering.
Chris
