RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Set ups of buggies - need help!
Old 08-04-2005 | 08:39 AM
Default Set ups of buggies - need help!
I wanted to download set up sheets from kyosho.com for my buggy but there isn't sheet for my buggy (I have inferno DX) so I will have to do that on my own. So could you tell me what gives the change of camber angle, toe angle (and what is the best set for rear and for front) and should be the suspension be low and hard or high and soft?
Thanks in advance!
Old 08-04-2005 | 03:52 PM
crazychris7's Avatar
Default RE: Set ups of buggies - need help!
A good neutral setup is... 2 degress camber front and rear, 1 degree toe out in front, 35 front, 30 rear in shocks, 5k<7k<3k in diffs. Front arms should be level with the ground after compressing the suspension a few times and the rear shafts should be level. If you are pushing alot in the corners, i usually run w/o the front swaybar because it gives you a lil more steering.
Chris
