RCU Forums - View Single Post - priming 3W50
Thread: priming 3W50
Old 08-04-2005 | 09:35 PM
johnflys1
Default RE: priming 3W50
All of those ideas are valid. My motor did the same thing. You will need to replace the reed valve. Remove the carb and base plate from the motor. Inspect the reed valve. You will find the reeds damaged. The valve is about $20 from Aircraft International. Make sure and seal the base plate down with some very light sealant during assembly. Your problem will go away. John
