RE: Genesis LE
[quote]ORIGINAL: ThermalRD
Abonnet, in my situation it has helped. However, i was using a LONG glo plug. Which is the WRONG glo plug. The Gen requires a short plug, or the use of 2 washers on that long plug. So if you're already using the right plug, your tune might just be off. And to be honest, i'd really like to run a few more tanks from start to finish before i decide that my half tank lean issue is solved. Although it ran perfect til it was empty last time. Oh, and that aluminum link was one of the items i had planned on months ago when i initially had ideas to buy a Genesis. I just simply havent had any problems with it, so i havent bought that part yet. I know many areas on the LE are beefed up, that may be one of the areas they updated. I know my truck has already taken some tumbles, and hits, with no problems.
THANKS THERMAL. Good to know they beefed up that part on the LE. It seems I missed the LE boat by about 12 month. Just bought my Genesis, had I waited a month... whatever, I just hope this thing is fun.
I have less than a gallon into it and it is running hot but, how hot is hot? HOW HOT ARE YOUR GENESIS RUNNING GUYS? thinking on buying the crazy nut head.
