RE: ucando 60
Beef up the landing gear block with some tri stock hard balsa or hardwood. Use poly glue to glue that in. I moved my rudder servo to the bottom in front of the tail wheel and went with a pul-pull. I also used small robart hinge points in the rudder and elevator. That 110 should fly the snot out of this plane! Watch the speed, she tends to flutter in fast flight.
