Originally posted by gjestico
Ensure the rear wing bolt block in the fuse is glued securely.
As you have heard, Keep everything as far forward as you can.
With an OS 1.60, Mine was still 1/2" behind the rearmost cg limit.
Greg J
How true.
My wing block came loose last season. It was one of those just fly around days without much crazy stuff. It just kept going out of trim so when I landed it OH!!!. put some screws through the fuse ply into the block and some 30 minute. Many flights since and no weakness.
I have a 1.80 Saito/1500ma nicad all as far forward as it will go just to get the CG right.
Though plane to balance without lead but a good flyer.
Mike
