Thanks for the comments: WhtBronco - your setup looks quite deluxe but thank-you for the recommendations. PHK - these setups are from Hong Kong and I am starting to be leary as the entire setup is $650.
What is the difference between the T-Rex 450XL (CDE) CCPM (it's yellow colored
http://store.xtremercproducts.com/t45ccckit.html) and the V3 that you mention?
I have been reading up and I was going to go a tad lower with the radio:
JR6102 (6665) or Optic 6. How can I find out which is the correct servo to put in without having to carve up the servo opening? Is there a reason to get the Futaba GY401 over the GY 240? What is the reason I need 7 or 9 channels? For the JR241 servo or Hitec HS56; These fit into the openings properly?
When it comes to the speed control, do I have to have the 35 amp as I see the bird/motor/25A speed control for $250 on the T-Rex 450 XL (CDE) CPPM
Thanks in advance guys as I'm just a begineer and don't want to spend a ton of money. I just want to get what I actually need and have fun!
