ORIGINAL: chmm
ok i am wanting to beld my own boat i have a 25cc wededer motor to use i would be running in ruff and sometimes smoth water and i donno if i should go with a deepv or a Catamaran i want someing that is goign to be fast so if some would could help me with what one is beter that would be graet and then what size of prop would be the best i want somethign around 38-45 inches
thanks chris
Hi Chris,
Not to be nasty in any way, but try using the spell check and learn to use interpunctions every once and a while.
This would make your "cry for help" so much more readable, specially if english isn't your native language.
Thrust me you're not the worst, or I wouldn't even bother to respond, simply because I wouldn't be able to understand the question.
Try using the search on weedeater, 25cc, Homelite and you'll find a world of information.
Also look in my gallery for pictures of a DeepVee for my 25cc Homelite.
Regards, Jan.
