need help
ok i am wanting to beld my own boat i have a 25cc wededer motor to use i would be running in ruff and sometimes smoth water and i donno if i should go with a deepv or a Catamaran i want someing that is goign to be fast so if some would could help me with what one is beter that would be graet and then what size of prop would be the best i want somethign around 38-45 inches
thanks chris
thanks chris
ORIGINAL: chmm
thanks chris
thanks chris
Not to be nasty in any way, but try using the spell check and learn to use interpunctions every once and a while.
This would make your "cry for help" so much more readable, specially if english isn't your native language.
Thrust me you're not the worst, or I wouldn't even bother to respond, simply because I wouldn't be able to understand the question.
Try using the search on weedeater, 25cc, Homelite and you'll find a world of information.
Also look in my gallery for pictures of a DeepVee for my 25cc Homelite.
Regards, Jan.
Spell Check will see trust and not think anything of it as trust is a word.
Not to pick on you in paricular but we have been getting a lot of new members the past few weeks whose spelling is atrocious. I know that you may use this kind of spelling in chat rooms and other places but it makes it easier for us old guys if you can try to spell better and use punctuation.
I go back through and check all of mine before hitting "OK", I'm a terrible typer. You ought to see how bad mine look before I send it! I corrected this one at least 6 times already.
Anyway, welcome to the site and we'll see what we can do for you.
Oops, make it eight.
