ORIGINAL:
[email protected]
you will have to tell me more about clutch removal because I just got unlazy and found the 2 motor tank controller on ebay and bought it. have you seen reference to changing the large drive gear to separate gears? i thought it would be possible but there was no reason to go be contemplation. now I must! came to 77 $ cad 62.50 U.S. any help !?!
You dont have to really have the remove the cluch set up.But it will give you more room to work with.BUT you do have to get the Opt.gears Thay are two smaller gears instead of the one large gear.I will take a pix and post for you.
