RCU Forums - View Single Post - plane wants to roll with full elevator
Old 08-08-2005 | 01:09 AM
3D-kid330
Default RE: plane wants to roll with full elevator
All are great advice. Check your CG also. (roll inverted from level and see if it pulls down hard, if it does, you could probably get away with a rearward CG; Ideally, you want the plane to fly level inverted and upright or pull very slightly when inverted.
I have many planes that snap with a foward CG, but once the CG is back enough, the snap is lessened or even eliminated.
Hope this helps,
Brandon
