First, there is nothing wrong with the Hitec AM radio. I used one with my Spirit Select RTF sailplane. Never a problem.
This is one you should consider seriously.
Multiplex Easy Star
R/E/T 1.4 M This is a cross between an e-glider and a parkflyer. We have
several
at our field. This is a good smaller first e-glider or a parkflyer. It a
very strong following. This is an Elapor foam plane that is very rugged,
flies well and thermals well. Makes a great "keep in the car"
e-glider/parkflyer.
ARF - $60
http://www2.towerhobbies.com/cgi-bin...&I=LXFRU7&P=ML
RTF with Radio - $189
http://www2.towerhobbies.com/cgi-bin...&I=LXFXV0&P=ML
Hanger 9 Aspire - $239 - RTF
R/E/T - 2M This is a traditional built up balsa glider with Polyhedral wing.
Many people add a gearbox to this plane for stronger climbs.
http://www.horizonhobby.com/Shop/ByC...ProdID=HAN1950
This Gear box and a 11 or 12X8 prop really makes the plane perform much better.
http://www2.towerhobbies.com/cgi-bin...?&I=LXSL79&P=M
This is a GD-600 Electric Flight 2.5:1 ratio Gear Drive Unit for
Electric R/C Airplanes Applications.
