RE: dragonfly
Hi,
Is it a Walkera Dragonfly 4?
They are only 4 channel. The switches are not connected inside.
And Dragonfly transmitters tend only to work with a specific Dragonfly receiver -
A Dragonfly 6 channel transmitter (has the knobs as well) will send 5 useable channels, but again only works with the DF 6 channel receiver.
Most Dragonfly RTF stuff is proprietary.
If you want to get something more, then buy a normal 6 channel transmitter, ideally one that supports heli's, and get a normal receiver... Then add a Gyro and ESCs.
That will add weight, but should work.
Also, E-sky is supposed to make some normal receiver units that add a gyro to the mix. Might be worth having a look at.
David
