Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
dragonfly
Old 08-11-2005 | 05:49 AM
Default dragonfly
hi there
Old 08-11-2005 | 05:54 AM
Default RE: dragonfly
hi there
the controller that comes with the 4ch dragonfly its got two silver swicthes at top does this mean it a six ch crontroller it also have servo reserve switches 1 to 8 on the back. if it is could i buy a dragonfly 6ch reciver on same mhz to put into my honeybee 2 6ch 3d any use the dragonfly controller on my honeybee
thanks any ideas
Old 08-11-2005 | 06:31 AM
Hi,
Is it a Walkera Dragonfly 4?
They are only 4 channel. The switches are not connected inside.
And Dragonfly transmitters tend only to work with a specific Dragonfly receiver -
A Dragonfly 6 channel transmitter (has the knobs as well) will send 5 useable channels, but again only works with the DF 6 channel receiver.
Most Dragonfly RTF stuff is proprietary.
If you want to get something more, then buy a normal 6 channel transmitter, ideally one that supports heli's, and get a normal receiver... Then add a Gyro and ESCs.
That will add weight, but should work.
Also, E-sky is supposed to make some normal receiver units that add a gyro to the mix. Might be worth having a look at.
David
Old 08-11-2005 | 01:42 PM
thanks for the reply ive pulled the controller apart and the swicthes are connected
how do you tell what type of dragonfly it is
