RCU Forums - View Single Post - Vector Flight Xtra 300 66" build
Old 08-12-2005 | 04:17 AM
suitcase's Avatar
suitcase
Default RE: Vector Flight Xtra 300 66" build
Thanks for the encouraging words. Yesterday I glued on the bracing on the stabs like VF suggests. I trial fit the ailerons and marked the horns after installing the servo. I lined the horn up with the servo arm marked it and removed the aileron to drill it. Installed the horn and stuck the aileron back on.[X(][:@] I should have squared it off of the aileron itself and not the servo. Studying it, I don't see how it's supposed to be installed. The tapered wing is throwing me off! I'm heading for the 540 thread to see if any suggestions are there on how to mount the controls.
Also, what kind of glue is used to glue on the tail fairing? Plus I'm considering changing the way the tail wheel wire is connected to the rudder. Is their procedure strong enough? I like the way my sticks are done with the wire going up between the rudder and stab and 90* into the rudder. Just looks stronger to me
