RE: Balsa USA North Star
Relatively speaking, it is a hard kit to build well and even harder to get properly balanced without adding excessive weight. It is also hard to trim for all throttle settings as the thrust line is so high above the center of drag. With computer capability to mix elevator with throttle, this won't be the problem it is with non computer radios.
