Two week ago I had this problem. To fix it please check the following:
1.- Take off you air filter.
2.- Check in the carbulator how many space you have in the neutral position.
They more often need around 1mm to 2mm of space.
3.- Press the break and see how many space you have in the carbulator.
Check it carefull....if it have a litter space for example 0.5mm ....this is the problem.
for increase the space or rpm.
Maybe you want to know how to adjust the rpm and something...please check the following link ...Two guy help me alot.
You can find all information. I give you a summary in the above three step.
http://www.rcuniverse.com/forum/m_23...18/key_/tm.htm
When you taking about
the engine is very hot. This is another reason the engine stop.....because the engine cannt receive a lot of fuel.
My suggestion is fix one problem and after to check another one. To fix the
the engine is very hot is try to rich the HSN. You can see in the pix of the link where is this screw.
ORIGINAL: Vince15
rwong21: when i stop and in the corner when the engine is on low rpm, always after lots of accelerations.... when the engine is very hot
BEEN THERE WRECKED THAT: where is gasket in fuel tank cause i don't see any ? :/
Sorry all but i forgon about sth ... when i changed muffler pipe for the ne one it hindered me to tighten the manifold ... i need to fix it right ?
