RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
The engine stops all the time :(
Old 08-11-2005 | 12:13 PM
Default The engine stops all the time :(
When I start my inrerno dx it runs very good but after a half of the fuel tank engine stops and i then it takes me ages to start it again. And it happens about two times every one tank. What can be wrong ? Help please!
Old 08-11-2005 | 02:04 PM
Default RE: The engine stops all the time :(
hi how old is your engine it sounds like lack of compression when the engine is hot(as the sleeve expands).that is my only idea which you can only solve by buying a new piston and liner.
Old 08-11-2005 | 03:27 PM
Oh it's preety old ... it's 5 years i think ... but at first i didn't run a lot.... but for a year i've been running much more.... btw, i need to buy a sleeve and a piston or sth more ?
Anyway thanks a lot for your reply ! ;-)
Old 08-11-2005 | 03:53 PM
SManMTB's Avatar
Also check for any holes in the fuel and pressure lines.
Old 08-11-2005 | 04:19 PM
I checked fuel lines and there is a small leak in fuel filter... can it be a reason that engine stops ?
Old 08-11-2005 | 04:27 PM
You said it heats up and boggs down and dies until it cools down? Thats definitely "Blow by", meaning its time for a rebuild or a new engine. Try replacing the fuel line, but I doubt thats the issue if the engine is indeed old.
Old 08-11-2005 | 04:38 PM
SManMTB's Avatar
ORIGINAL: Vince15
Ohhh yes!
edit:
I bet you $5 (of imaginary money) that it runs after you fix that leak.
Old 08-11-2005 | 04:57 PM
ORIGINAL: SManMTB
ORIGINAL: Vince15
Ohhh yes!
edit:
OK we will find out when i fix it tomorrow.... ;-)
i though about rebuilding the engine so anyway i'll have to do that .... i see
Old 08-11-2005 | 08:21 PM
When the engine stop...? When you accele or stop or in the coner.
Old 08-11-2005 | 08:33 PM
Buy a new gasket set for the gas tank the seals could make the engine die at half tank that is what happened to me
Old 08-12-2005 | 05:50 AM
rwong21: when i stop and in the corner when the engine is on low rpm, always after lots of accelerations.... when the engine is very hot
BEEN THERE WRECKED THAT: where is gasket in fuel tank cause i don't see any ? :/
Sorry all but i forgon about sth ... when i changed muffler pipe for the ne one it hindered me to tighten the manifold ... i need to fix it right ?
Old 08-12-2005 | 06:45 AM
Banned
Also, how is the clutch internals looking? possibly a prob there too if it happens on deceleration.
Old 08-12-2005 | 12:41 PM
Two week ago I had this problem. To fix it please check the following:
1.- Take off you air filter.
2.- Check in the carbulator how many space you have in the neutral position.
They more often need around 1mm to 2mm of space.
3.- Press the break and see how many space you have in the carbulator.
Check it carefull....if it have a litter space for example 0.5mm ....this is the problem.
for increase the space or rpm.
Maybe you want to know how to adjust the rpm and something...please check the following link ...Two guy help me alot.
You can find all information. I give you a summary in the above three step.
http://www.rcuniverse.com/forum/m_23...18/key_/tm.htm
When you taking about the engine is very hot. This is another reason the engine stop.....because the engine cannt receive a lot of fuel.
My suggestion is fix one problem and after to check another one. To fix the the engine is very hot is try to rich the HSN. You can see in the pix of the link where is this screw.
ORIGINAL: Vince15
