RE: OS 61 Hanno Special question
You do not have to run the hanno at such low RPM. If you need the power and can stand the noise use a four inch header and a Macs 10cc standard muffled pipe and a 12-7 or 8 prop. The OS pipe has a very narrow rpm range, the Macs pipe will rev higher in the air.
