RE: prop size?
Hi Raz,
As a rule, the Graupner props I use from the K-series are mostly a bit larger than the advertized size, but once I've taken off the burrs and sharpened the leading- and trailing edges, the props are the correct size, or marginally smaller, depending on how much I take off sharpening.
The plastic ones deviate even more.
Regards, Jan.
